Bradleysf5trinidad Posted July 1, 2015 Share Posted July 1, 2015 Hello and thank you in advance for all of your help and suggestions. I've bought an old sf5 that's been swapped and had a host of problems that i've been trying to sort out on my own. The car hasn't had a good life and it shows. 2 years ago its been swapped with a gc8 wrx motor mated to a type ra 4.44 close ratio box and differential. It works for the most part but it's never had a working speedo. Lots of other things work. It's got rpms, temp, fuel, outside temp. It has no check engine light and the obd port has no power to it. My issue is that it gets speed cut. The gear box has the three wire speed sensor, I've got a manual forester gauge cluster and manual forester 4W 3 plug ecu. I need help fixing the speedcut. i would like to wire the speed sensor directly to where the signal needs to go. I've tried sending the speed sensor signal to the ecu and it has no effect. also tried a different ecu because i had that option and it didn't work either. I've tested the speed sensor output and the sensor works well, the issue is the correct wiring of the speed signal to supposedly the gauge cluster. In trinidad we get international versions of japanese cars as well as roll on roll off jdm versions. I believe this car is an international version that was a automatic when stock. Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 1, 2015 Share Posted July 1, 2015 Speed signal is supposed to go to the cluster, and cluster converts it to a different signal that is sent to the ECU. Some years had problems with a solder joint on the speedometer unit in the cluster. Its fixable with some wire and a soldering iron. There is a thread here somewhere that shows how to fix it on a legacy. Could be similar on the Forester. Link to comment Share on other sites More sharing options...
