2001 outback frontend clicking (not cv's)
Hello, I am new to the forums. So the 2001 outback wagon (auto 2.5)  has a clicking coming from the front end.  checked it out and presumed it was one of the cv's. SO I completely replaced them both.  Test drive.... still cliicking.  Anyone on here have any ideas as to what may be making the noise?  noise is a clicking It only occurs when applying throttle, not when coasting, the frequency of clicks goes up with speed.  it clicks under braking and under engine braking.  sounds the same with the wheels turned as not.
Any help would be most appreciated
Thanks
Tomas
disc brake hitting something
or
front diff
check front diff gear oil level and condition.  if drained, check for bits, chunks, or metal in the oil.
aftermarket axles are prone to issues - so make certain it's not one of them - even the "new" axle.  if the sound absolutely made no change before/after the axle replacement then it's probably not the axle - even a junk axle would probably make at least a different noise.
a wheel bearing might cause this - but that's not a normal symptom and you would probably have some inclination as to whether it was the left or right side causing it.  having someone stand outside and listen or hanging out the front windows might help determine if it's left, right, or central.  left/right would suggest wheel bearing.  central would suggest front diff (if you're positive it's not he axles).
generally a used transmission is used to repair that.
www.car-part.com
Edited by grossgary
Looks like it is the front diff.  damage to the ring gear. some metal bits in the oil.  swapped fluid for lucas but it still making noise.  So replacing the whole transmission is the way to go?  or replace diff internals? or replace diff?
Thanks everyone for the advice
Much appreciated
Tomas
