johnvaudo Posted July 5, 2015 Share Posted July 5, 2015 ok here is my situation. drivers side front outer CV joint has blown out. Axle nut appears to be over torqued or seized. have tried impact wrench not success, have used a torque wrench set in excess of 200 ft/lbs. broke the torque wrench. have soaked it all day with WD-40 have tried bouncing ( I am 200#) on a 24" 1/2" drive Breaker bar NOTHING!!!! Can use some serious advice can't replace the half shaft until I get this bloody nut off. Thanks John Link to comment Share on other sites More sharing options...
idosubaru Posted July 5, 2015 Share Posted July 5, 2015 (edited) i've found like 1 out of 20 (or some number like that) are incredibly nasty to get off. 1/2" stuff will break and huge impacts won't budge them. 2 foot isn't enough leverage - you need 3-5 foot pipe over the socket wrench handle. i have a 3/4" 900 ft/lb impact gun that hasn't removed the really bad/seized ones. for those i have to use my 3/4" socket set and a 4 foot pipe and still give it some serious stank. or crack, drill, cut off the nut. Edited July 5, 2015 by grossgary Link to comment Share on other sites More sharing options...
johnvaudo Posted July 5, 2015 Author Share Posted July 5, 2015 i've found like 1 out of 20 (or some number like that) are incredibly nasty to get off. 1/2" stuff will break and huge impacts won't budge them. 2 foot isn't enough leverage - you need 3-5 foot pipe over the socket wrench handle. i have a 3/4" 900 ft/lb impact gun that hasn't removed the really bad/seized ones. for those i have to use my 3/4" socket set and a 4 foot pipe and still give it some serious stank. or crack, drill, cut off the nut. WOW thanks for the insight I was a Mech in the National Guard and had some that bad never thought I would run in to something this bad Link to comment Share on other sites More sharing options...
idosubaru Posted July 6, 2015 Share Posted July 6, 2015 Oh yeah, i've seen a few. They're really annoying. I'm still really annoyed my nearly 1000 ft/pound impact won't get them off. i saw a shop work on one once for a Subaru - it wasn't budging either - he let their impact hammer on it for like 3 minutes...i was thinking (what is he doing, it's not working)....and after like 3 minutes it finally zipped off. Link to comment Share on other sites More sharing options...
turbosubarubrat Posted July 6, 2015 Share Posted July 6, 2015 I use a 3/4" Ingersoll-Rand impact and it works great. On some of the stuck stuff you have to keep the impact on for a awhile until they break loose. Had a transmission drain plug that was so tight i had to use the 3/4" on it because it wouldn't budge with a 25" breaker bar with a cheater bar. Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 7, 2015 Share Posted July 7, 2015 Just for future reference, torque wrenches are never to be used for loosening. Torque wrench = tighten only Axle nuts suck. I put a wheel bearing on a friends honda about 3-4 years ago and a couple months back the bearing started making noise. (Cheapo bearing) I torqued the axle nut with my torque wrench when the bearing was originally replaced. I broke two breaker bars (craftsman) trying to get that axle nut loose. Finally had to go get a 3/4" drive socket to fit the axle nut and put a borrowed 3/4" breaker bar on it with a 5 foot pipe. Had to get my 300lb friend to stand on the pipe to crack the nut loose. Same car I had to buy a special tool to hold the crankshaft pulley so I could get the crankshaft bolt loose to change the timing belt. That took a 4 foot pipe to get a 19mm bolt loose! 1 Link to comment Share on other sites More sharing options...
ford'ssubaru's Posted September 13, 2015 Share Posted September 13, 2015 A little heat from a propane torch does wonders........ 1 Link to comment Share on other sites More sharing options...
crazyhorse001 Posted November 24, 2015 Share Posted November 24, 2015 A little heat from a propane torch does wonders........Nothin, but NOTHIN can stand up to Smokey the Big Blue Wrench Besides theres something uniquely macho about burning steel with fire *grin* I've had luck putting a big cheater on a 3/4 breaker and driving the car a foot or two to crack really stubborn ones. Kinda like putting a breaker on the crank bolt and bumping the starter. Not 100% foolproof but usually does the trick 1 Link to comment Share on other sites More sharing options...
mikaleda Posted November 30, 2015 Share Posted November 30, 2015 Nothing like a bit of liquid wrench (and I mean the original liquid wrench called a torch) And a BF breaker bar and pipe. Link to comment Share on other sites More sharing options...
