kenoterry Posted May 26, 2004 Share Posted May 26, 2004 Anyone know for 1.8 turbo OHC 1990 EA82 motor if the valves will be damaged by a broken timing belt? Link to comment Share on other sites More sharing options...
Turbone Posted May 26, 2004 Share Posted May 26, 2004 Lefty loosey, righty tighty. Link to comment Share on other sites More sharing options...
Guest taprackready Posted May 26, 2004 Share Posted May 26, 2004 I've never heard of anybody complaining about bent/broken valves from EA82 timing belts breaking. I think they are non-interference engines. Bill Link to comment Share on other sites More sharing options...
Marck Posted May 26, 2004 Share Posted May 26, 2004 right, just replace the belts and your good to go. Both belts must be replaced and it is a good idea to replace the cam seals, front crank seal, oil pump seals or oil pump, and water pump. Check your tensioners and idlers. Link to comment Share on other sites More sharing options...
calebz Posted May 26, 2004 Share Posted May 26, 2004 EA82 is non interference. No valve problems as a result of broken timing belts. Link to comment Share on other sites More sharing options...
Kirk Yarina Posted May 27, 2004 Share Posted May 27, 2004 Didn't on my 89 Loyale. Just got it fixed, after spending the winter under a snowbank, and my 16 yo daughter's driving it. Link to comment Share on other sites More sharing options...
ShawnW Posted May 27, 2004 Share Posted May 27, 2004 A very small few have but not many. Probably something like 0.005% Link to comment Share on other sites More sharing options...
subiemech85 Posted May 27, 2004 Share Posted May 27, 2004 no if the left breaks, it won't run, drives dist if right breaks, it will still run change them after they break even on the side of the road Link to comment Share on other sites More sharing options...
