subaru gl
Id does bolt up perfectly but you will have to swap all the associated rear suspension, driveshaft, differential. You will have to fashion a mount for the carrier bearing. You will have to drill and use thru bolts for the rear diff hanger, although the holes are stamped in the body for yoou to drill out.
Look who's back!
