GL-10 turbo fuel filter[s]
as far as i know yeah, only 1, its by the shock tower above the brake fluid reservoir. i changed mine from the original to a WIX branded one in june 2014, so far so good.. (knock on wood)
Edited by Subasaurus
If it's still got the factory fuel pump, there's also a strainer sitting inside the inlet (to catch stuff that might be in the tank), but it's not replaceable.
Just take the pump out & clean it.
If there's an  aftermarket pump, make sure there's a filter between it & the tank.
Edited by wagonist
  • Like 2
