zmarrott Posted July 23, 2015 Share Posted July 23, 2015 i need help with my car. just got a 3 door 1988 GL 4x4 and it ran good when i bought it, but now it wont stay running when i put any load on the engine. i can get it to idle, then if i put load on it, it sputters really bad and stalls. takes a bunch of tries starting to get it to stay running again. the ea81 was put in by the previous owner, and it has a 2 barrel weber carb that i was told needs adjusting. im stuck cuz i have to drive 700 miles and my other car just broke down Quote Link to comment Share on other sites More sharing options...
tweety Posted July 23, 2015 Share Posted July 23, 2015 Check for vacuum leaks. 4 bolts only holding the carb on, worth taking the carb off and its bottom mount to see if there are leaks. One hour job. Then other vacuum connections and if all that fails to locate it (try to run the engine) then manifold to head gasket check. Failing that try to rev the engine and look down the carbie throat to see the fuel squirting down. If its dribbling then take jets out and blow air thru them. try again. Just my ideas. good luck Quote Link to comment Share on other sites More sharing options...
zmarrott Posted July 23, 2015 Author Share Posted July 23, 2015 i was able to drive just over 200 miles with a few stall outs, but now it wont start. im pretty sure its the coil pack though. gonna get one and check Quote Link to comment Share on other sites More sharing options...
jono Posted July 23, 2015 Share Posted July 23, 2015 coil pack normally means more than one coil for the engine. What sort of ignition you got ? check al your earth connections, battery terminal posts, clean 'em all with sand paper stuff, retighten. Quote Link to comment Share on other sites More sharing options...
zmarrott Posted July 24, 2015 Author Share Posted July 24, 2015 i was the coil. replaced and running fine now 1 Quote Link to comment Share on other sites More sharing options...
