Noise after an engine swap on a 1990 Subaru Legacy
Hello.  So my friend did an engine swap on his 1990 Subaru Legacy.  During the change the shaft came out of the torque converter.  Now, when we start the car there is a clunking kind of noise.  Any suggestions on what can be causing that noise or how to fix it would be so helpful.  Are there any spline alignments in the engine?
Probably didn't fully seat the input shaft. Often it hangs up 1/4 inch from being fully seated. If the car still moves in gear than that means you haven't destroyed the transmission pump. As for the noise, are the TC bolts tight?
Noise seems to me just about has to TC related.
