I have a 94 legacy gt 2.2, manual transmission with a shot drive train and a 97 legacy gt 2.5 manual transmission with a shot engine. Can I regear the 94 with 97s equipment? Can't really find anything online about it, though I'd ask you guys.
97 GT will have a hydro clutch I think, so you will need to move the pivot ball and replace the throwout fork with the cable clutch one to use that transmission in the earlier car. Or convert the firewall/pedalbox to hydro clutch. I personally prefer the feel of a cable clutch.
But yes, trans and rear diff should swap in. The VSS unthreads and the speedo cable threads in where it went. The rear axles may require a bit of mix and match, I forget when they went from having stubs that stuck out of the differential to having the axles plug into the differential. Between the two cars you should have all the parts needed to make it work.
