first gen leg with auto belts, they failed...duh they all do
customer wants to know if i can install seatbelts out of a newer  legacy in her car, anyone done this? im sure its easy but want some feedback before i spend her money
you should be able to manually crank the belt/buckle part into the upright/closed position, then unplug the control box in the rear of the car so it will not move again.  then it is simply a matter of unbuckling the belt to get in/out of the car.
the other half did this with his 90 sedan for more than a year - no extra work needed.
  • 2 weeks later...
