Loyale 2.7 Turbo Posted August 12, 2015 Share Posted August 12, 2015 On 8/12/2015 at 11:32 AM, xntryk1 said: I promise, I DID check the fuses - at the very beginning (when I just had high beam on the LH side and no low beam). But then I didn't check them again, until the very end. Sorry to waste everyone's time trying to diagnose something that had such a simple fix. I know... what really happened was that Originally the bulb's Socket was bad, but the Fuse was good; then when you cut its wires from the old Socket to put the new one, you blew the Fuse and did not check it again... until now; that's a normal thing to happen which only the Experience will taught you to know how to do these kind of repairs. I bet that next time you'll be checking Fuses / relays \ Wirings in a different way. Kind Regards. 1 Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 12, 2015 Share Posted August 12, 2015 Pretty much with any electrical repair if you fix one problem and then have a new problem, you have to go back to square one and recheck all the basics. It doesn't always work out perfectly the first time around. Link to comment Share on other sites More sharing options...
mikeamondo Posted January 12, 2016 Share Posted January 12, 2016 Hello.... just a quick note to the participants of this thread.... Thanks for saving me a bunch of money and time! And specifically to xntryk1.... dude, don't feel bad. I've been trying to track down this issue since I replaced my LH harness 2 months ago... same thing... dim headlight, no highbeam. Due to the fact that the bulb was on dimmly, I thought the fuses must be good and failed to spend the 30 seconds to check..... duh. Best advice on this thread.... with electrical problems, treat every change like a fresh start, double checking all the little things..... Once again, USMB saves me money! Thanks! Link to comment Share on other sites More sharing options...
brus brother Posted January 13, 2016 Share Posted January 13, 2016 (edited) Edit: nm just realized this was solved I was responding to post on page 2 gotta check my brain fuse!!! Edited January 13, 2016 by brus brother Link to comment Share on other sites More sharing options...
