Nickgonz Posted August 3, 2015 Share Posted August 3, 2015 HI, I have recently started to get a load thud/clunk noise when shifting from park into reverse. No problems at all with forwards gears. Noise happens less often when car is warm but still happens. I've tried disengaging the AWD by inserting the fuse, still happens. Had a look at the trans fluid level/condition, looks good. Any help or ideas on how I can narrow it down would be greatly appreciated. Cheers in advance. Link to comment Share on other sites More sharing options...
Nickgonz Posted August 3, 2015 Author Share Posted August 3, 2015 BTW I should have mentioned it's a 2001 Forester. Link to comment Share on other sites More sharing options...
Bushwick Posted August 3, 2015 Share Posted August 3, 2015 Could be a universal joint for the driveshaft or engine mount. I know with old Fords that was a symptom of a u-joint. To rule out engine movement, open hood and watch top of intake manifold and go from a forward gear to reverse. If you have a helper, have them do it instead and watch the trans and engine for abrupt moving like lifting and dropping. For the driveshaft, you should be able to grab it and try twisting it and working back and forth. If a u-joint is bad, the shaft will be loose at one end or both. 1 Link to comment Share on other sites More sharing options...
CNY_Dave Posted August 3, 2015 Share Posted August 3, 2015 (edited) Could be any of the mounts have become loose or worn, including the rear diff rubber mounts. Looking underneath *from the side* while someone *you really trust* works in from D to R can be helpful. Edited August 4, 2015 by CNY_Dave Link to comment Share on other sites More sharing options...
Nickgonz Posted August 3, 2015 Author Share Posted August 3, 2015 Awesome thanks a lot for your help. Now to find somone I trust enough to shift the gears whilst I'm under it. Definitely sounds like it's coming from the front end/transmission. Link to comment Share on other sites More sharing options...
Bushwick Posted August 4, 2015 Share Posted August 4, 2015 To be safe, you should block all 4 wheels front/back. Explain to whomever does this NOT to touch the gas pedal either unless their other foot is firmly on the brake + the wheels are blocked. Goosing it lightly can show movement. Link to comment Share on other sites More sharing options...
CNY_Dave Posted August 4, 2015 Share Posted August 4, 2015 I would do it from the side and use a mirror on a stick if need be. Or a phone on a selfie stick (the only proper use for one, remote video!) Link to comment Share on other sites More sharing options...
Nickgonz Posted August 4, 2015 Author Share Posted August 4, 2015 Cheers for all the input. Managed to get clos enough the to have a look and after noticing a "fair" bit of movement - turns out the trans mount is well and truely gone. Will order and replace. Hopefully this resolves the issue.Thanks again Nick. Link to comment Share on other sites More sharing options...
