sumoco Posted August 5, 2015 Share Posted August 5, 2015 DISCLAIMER: If you're just going to say please don't chop up this car/this is going to be too hard you just shouldn't do it/really anything that isn't constructive advise on what I should do, please don't say anything at all So I currently have a 78 wagon in almost perfect condition that I would love to turn into a sleeper, I have a connection for a 1st gen turbo legacy that I'm going to strip for parts and I have a couple questions on this; 1.since I want awd would it be absolutely impossible to swap ej crossmember,arms, blah blah blah so that I wouldn't have to make custom axles + I would gain the strength of ej axles and have a decently wide stance, I know I need to get under my car and really check spoob out but I want know if some has done it before 2. No matter what I want an ej tranny, so should I find a 1st gen legacy 5 speed or should I upgrade to a 6 speed, I'm pretty sure I'm going to have to give it a slight lift/crossmember drop to fit this under the car though, which is fine since I want some wider racing tires so I'm not slipping every time I gun it. 3. Is a turbo swap any different from a base ej22 swap, cut everything that isn't in the engine bay correct? Anyway, I'm super excited to begin this Link to comment Share on other sites More sharing options...
turbosubarubrat Posted August 5, 2015 Share Posted August 5, 2015 I would start by measuring the width of the legacy hub to hub and the 1st gen hub to hub to see how much the width difference is. A ea81 car is about 3 inches narrower than a ea82 which means the ea71 cars are even smaller. I know the legacy is wider than the ea82 but i don't know how much. Depending on how much wider the legacy is you might be able to find a different off set rim that might work. Other wise use the ea81/ea82 5 lug swap/suspension upgrade on this with the stock cross member. Probably best off doing what some have done which is cutting the 2 front sets of axles up and welding/sleaving them. 1 Link to comment Share on other sites More sharing options...
sumoco Posted August 5, 2015 Author Share Posted August 5, 2015 Alright so the legacy is about 5.5 inches wider(2.75 on each side) someone took the crossmember so I couldn't measure that out, but that doesn't seem to bad, nothing rolled fenders and a nice offset couldn't fix Link to comment Share on other sites More sharing options...
