Aluxes Posted August 5, 2015 Share Posted August 5, 2015 Im replacing the old worn stock struts, 97 Imp OBS, with BC coilovers. Im wondering what else, suspension wise I should change while in there? Ive already upgraded to 22mm swaybars and whitline endlinks so those bushings are good. Just not much of a suspension guy, so need a little advice. I think, a while back, Subaru dealer may have told me I needed to replace tie rods, or maybe it was ball joint. Dont remember though. Link to comment Share on other sites More sharing options...
Aluxes Posted August 10, 2015 Author Share Posted August 10, 2015 Was thinking something like this. http://www.ebay.com/itm/151484239679 Link to comment Share on other sites More sharing options...
lstevens76 Posted August 10, 2015 Share Posted August 10, 2015 If your lowering your car, then yeah that might be an option. Otherwise I would go with OEM ball joints, if they are bad. But before doing anything I would jack the front of the car up and get it on jack stands then get up under there and check the ball joints/tie rod ends for problems first. Link to comment Share on other sites More sharing options...
