Mikevan10 Posted August 8, 2015 Share Posted August 8, 2015 I guess there is a special Subaru tool for separating the fuel line fittings on the top left hand side of the engine? These are the fittings with the yellow plastic sleeves inside. I did a search and did not learn much. There has to be trick? Or is there a tool I can borrow from Auto Zone or something. Need to get this engine out tonight! Please help. Thanks! Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 8, 2015 Share Posted August 8, 2015 Its a quick connect fitting. If it has a sleeve, usually you just push the sleeve into the fitting and it will pop loose. I usually use a wrench that just fits around the line to push the fitting with. It may require some PB or other penetrating oil. And try pushing the fitting together and twisting slightly before pushing the sleeve in. Link to comment Share on other sites More sharing options...
Mikevan10 Posted August 9, 2015 Author Share Posted August 9, 2015 (edited) Thanks, as always. Tax, The motor is out and the new turbo fitted. Still have not figured out the QD fuel fittings but just separated the line at the regular hose fittings which are just upstream/downstream of the fancy fittings. Edited August 9, 2015 by Mikevan10 Link to comment Share on other sites More sharing options...
Mikevan10 Posted August 10, 2015 Author Share Posted August 10, 2015 Just thought I'd pass on how we got these fittings off. My kid picked up this tip: Cut a tie wrap (aka zip tie) in half (so you have square ends to work with). There are two tabs inside of the yellow plastic sleeve in the fittings located 180 degrees apart from one another. Examine carefully and locate these two tabs. Then insert the square ends of the tie wrap so that you push the tabs away from the metal pipe. Pull fitting off of pipe. Pretty simple. Link to comment Share on other sites More sharing options...
