Need help finding a replacement, don't know the name of this line or where to find it. It is in the very front/bottom, it has a rubber fitting on each side, and two tabs holding it onto the timing chain cover. It comes from the thermostat area and goes to the oil filter area.
Year and engine size please. oops didn't see title.
Edited by desertsubaru
Its fairly cheap from the dealer.
I would use just hose before using copper.
Anticipate similar rust on the one that goes under the drivers side head (but above the frame).
Check your oil pan for rust-through leaks.
