Killjoy6970 Posted August 10, 2015 Share Posted August 10, 2015 I've heard that I can put Forester struts on my '98 Impreza outback sport, what year Forester struts can be used? Help/advise is greatly appreciated, R/Chris Link to comment Share on other sites More sharing options...
Prwa101 Posted August 10, 2015 Share Posted August 10, 2015 I'd go 03+ forester struts, spring and top hats. You can typically find a set on CL for cheap from someone who just slammed there's. Link to comment Share on other sites More sharing options...
bratman18 Posted August 11, 2015 Share Posted August 11, 2015 98-08 Forester struts will fit. The rear top hat needs to be swapped from your struts, or drill new holes. Fronts bolt right in. 03-08 will have a higher rear spring perch so fit larger tires. You'll want the trailing arm bracket from an outback or block yours down to recenter your rear tires in the wheel well. Link to comment Share on other sites More sharing options...
