1993 Legacy transmission problem
  • 1 month later...
my daughters 05 legacy is doing something similar, it is an auto, but when starting out or accelarating after coasting, the engine revs and then the transmission engages. It is like having the clutch pedal depressed on a manual and letting it out, it will grab, but not quickly and has to be over 2k rpm. Is there a vaccum line that could be malfunctioning? Or does it sound like something worse/
There are no vaccume controls on the 4eat (the transmission that is in both of your cars), the 05, you may have a different issue. For the o.p. it sounds as if you are experiencing a mechanical failure in your transmission, but it is hard to tell as you describe it. Does it act the same way if you manuely shift it?
