bork Posted August 11, 2015 Share Posted August 11, 2015 If I find the right transmission & gear ratio, is it best to find an impreza tranny? Aren't they made in Japan? Or are all the trannys made in Japan? Or maybe Legacy is from USA? Are they better? etc... Link to comment Share on other sites More sharing options...
johnceggleston Posted August 11, 2015 Share Posted August 11, 2015 i have never read or heard a comment one way or the other. i do not think it matters. Link to comment Share on other sites More sharing options...
idosubaru Posted August 11, 2015 Share Posted August 11, 2015 +1 doubt it significantly matters. getting a bead on prior history/maintenance would be a better indicator i think. get one from an impreza with EJ18 - reasonable chance it's seen less taxing use from the small engine? Link to comment Share on other sites More sharing options...
bork Posted August 11, 2015 Author Share Posted August 11, 2015 My impreza is an 1999 with screw on filter. I dont think an EJ18 will work, on my 99? Link to comment Share on other sites More sharing options...
idosubaru Posted August 11, 2015 Share Posted August 11, 2015 (edited) My impreza is an 1999 with screw on filter. I dont think an EJ18 will work, on my 99? EJ18, EJ22, and EJ25 transmissions are interchangeable if not the same thing, if an Ej22 trans will work an EJ18 will work. the issue for you is that yours is a Phase II transmission so you need to use 99 - 2002 transmissions and possibly 03-04 will work too. www.car-part.com i don't think you can use 98 and earlier as they are Phase I and electronically different from 99+. if yours has the delayed engagement into drive issue that's specific to 99 only transmissions, there's an easy fix for that. Oh - and a screw on filter - so that means we're talking about a 1999 automatic transmission, you never stated what trans you're talking about. Edited August 11, 2015 by grossgary Link to comment Share on other sites More sharing options...
bork Posted August 12, 2015 Author Share Posted August 12, 2015 Ooops , yes auto. Link to comment Share on other sites More sharing options...
