94 Loyale no spark after crossing booster cables
So I've recently acquired a 94 Loyale which is not running.  The previous owner crossed the jumper cables while boosting another vehicle, and since then the engine is not getting a spark.  It turns over ok and seems to be getting fuel.  Distributor and coil have been replaced and fuses/relays have been checked.
Has anyone had a similar experience?  I'm not sure where to start troubleshooting.  I do have a running parts car.
All fusible links are ok, and I have 12V on the 2 outer terminals on the ignition coil.  I would think that's all it needs....power at the coil.  I did a standard (primary, secondary) coil test.
I've also noticed that the light on the ECU does not illuminate.  On my other (running) Loyale it blinks 5 times every few seconds.  In addition to that, there's no 'check engine' light when the ignition is on.  On my other Loyale there is.
Also, horn and hazard lights inoperative but they're getting power at the fuse box.
Edited by jetpilotdc10
UPDATE:  Hazard lights are working, horn does not.  My biggest concern now is no CEL and no light on ECU with ignition on.  I'm guessing that this is not normal?
I just tested the ECU in another vehicle and it seems to work fine.  Now I'm starting to think it's bad wiring to/from the ECU.
