Dwayne Oxford Posted August 14, 2015 Share Posted August 14, 2015 Seems dealers parts lookup now only goes back to '85. Anybody know if there's parts pdf's one can download to get parts numbers? Right now I'm needing the bypass hose for the water pump for '83 1.8. Parts guy at Nashville, TN said if I could get it's number they might be able to get it. OEM Subaru rubber is 2nd to none, WAY superior to after market. Link to comment Share on other sites More sharing options...
coxy Posted August 15, 2015 Share Posted August 15, 2015 (edited) If you mean the hose from the Water pump back to the steel manifold pipe then the number and description are as follows. Hose 15x22x56x101 part number 807615021 year 1982 (Should be the same) from a pdf Subaru of America Parts listing. I seem to remember I came across it on one of the experimental Aircraft sites along with the Factory service manual a google search should net you a copy Edited August 15, 2015 by coxy Link to comment Share on other sites More sharing options...
Dwayne Oxford Posted August 15, 2015 Author Share Posted August 15, 2015 Thanx, coxy. Found it @ http://jdfinley.com/file-downloads/subaru-manuals/ Link to comment Share on other sites More sharing options...
