tregare Posted May 27, 2004 Share Posted May 27, 2004 Ok, I'm looking at my wifes soob, i'm getting exhaust gas into the cooling system, is there any way to tell with a compression gauge if it's a blown head gasket or cracked head? or am I gonna have to strip the engine out and pull the heads and have them pressure tested? Link to comment Share on other sites More sharing options...
MorganM Posted May 27, 2004 Share Posted May 27, 2004 tregare said: Ok, I'm looking at my wifes soob, i'm getting exhaust gas into the cooling system, is there any way to tell with a compression gauge if it's a blown head gasket or cracked head? or am I gonna have to strip the engine out and pull the heads and have them pressure tested? Any more symtoms? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 27, 2004 Share Posted May 27, 2004 Just pull the head. You know you have to anyway, and you will probably be able to see if it was the HG or not. And any cracks in the heads you will probably be able to see with the naked eye. Only if you can't see any cracks, and the HG looked good would I consider pressure testing it. But I would might just put on a known good head instead at that point. Depends - what engine is it? EA81 heads are only $75 each from AHR here in Portland. I can't imagine you could get your head pressure tested and what not for much less. EA82, or EA82T heads could be more tho..... GD Link to comment Share on other sites More sharing options...
tregare Posted May 27, 2004 Author Share Posted May 27, 2004 yeah, I know it's going to have to come off so I can do the gasket. this is a 86 EA82 SPFI. I had a line on a pair of known good heads but i suffered a catastrophic email meltdown and lost the guy in oregon's email address Link to comment Share on other sites More sharing options...
