fuel troubles
i'm having troubles with the fuel pump i think. i'm the proud 1st time subaru owner. she's an '85 wagon, a little past her prime, but still solid in the 4x dept. i've changed fuel filters several times....brand new filter in today and still not pumping up to the engine....verified by observing fuel hoses at carb inlet....fuel pump fuse is good, she has gas....anybody care to give me a hint where to look for the fuel pump? in the tank maybe. anyhow, the car is broke and 35 miles from home...i'm too cheap to spend money on a tow truck, so i'm hoping for suggestions of how to get enough fuel flow to the carb for 35 miles of limping it home to the shop where i can open it up
on my 85 the line in the tank clogged up. i couldnt get it unclogged, so i bought some extra fuel line and put in the top of the tank where the sending unit is. i routed it to the the pump and hooked it up. it works pretty good.
to check the tank line just unplug the bigger line going to the tank and the fuel pump. some fuel will run out of the lines, but wait and see if it has a steady flow coming out of the tank.
fuel pours from the filter "in" hose....is the fuel pump before or after the filter...or better yet...a general idea of where to find the fuel pump at all...thanks for the quick reply and the idea of just sub-arooing a alternate fuel line in though...kirby
