Have the power coming in to both main n FP relays, but none coming out even though I've tried 3 different relays in each.  Wouldn't have thought all those relays could been fried, but maybe when a friend was changing them out they could of if the battery wasn't disconnected?  FP relay does click now though when clutch is depressed, and there is power going to ECU through the yellow wire pin 85.  Anyhow it's still quite the head scratcher, and I wish I could get it running!!!!!!!
Still?
Can you feel the relays click on when you turn the key?
You have 12v going into the relay when its on?
But you have no voltage coming out of the relays when they're on??
The fuel pump relay will only stay on for about 3 seconds unless the engine is running.
If you have 12v on the yellow wire at the ECM, that's the same wire that gives power to the center yellow wire of the ignition coil, do you have 12v there?
  • 2 weeks later...
Hey Fairtax haven't had the time nor the weather cooperation to get after it, but yeah no voltage coming out of either relay power is going in though.  Will have to check the power to the ignition coil when I get the chance.  Much funner car to drive than my rattle trap gas guzzling truck!!!!  :)
