ihscout54 Posted September 2, 2015 Share Posted September 2, 2015 On 9/1/2015 at 10:31 PM, ihscout54 said: Are you sure its the same code? Im guessing you cleared the codes. You need to verify the specification code after removing the ground. Make sure there is no way that you are getting ground to pin 33. 5: M/T Federal emissions (wire disconnected) 6: M/T Cali (wire connected) 7: A/T Fed (wire disconnected) 8: A/T Cali (wire connected) Unless the ECM is bad or the Loyale ecms are different, Im unsure of how you can still get this code with pin 33 ungrounded. Read this post again. Find out what mode your ecm is running. That code doesnt exist on the mpfi chart, and its in exception (cali only) on spfi. Link to comment Share on other sites More sharing options...
TomRhere Posted September 2, 2015 Share Posted September 2, 2015 I chased what I thought was a code 55 in my '88 Wagon. What I finally determined is that it actually is doing the spec code and not a 55 code. I sat in the seat and watched it blink for a few minutes. 5 flashes, short pause, 5 flashes, long pause, then it repeated over and over. Turns out that the second set of 5 flashes are the same duration as the first set. So that says it's flashing a 5 only, not a 55. Had me chasing my tail for a bit. Maybe that's what yours is doing. Link to comment Share on other sites More sharing options...
ihscout54 Posted September 2, 2015 Share Posted September 2, 2015 On 9/2/2015 at 8:48 PM, TomRhere said: I chased what I thought was a code 55 in my '88 Wagon. What I finally determined is that it actually is doing the spec code and not a 55 code. I sat in the seat and watched it blink for a few minutes. 5 flashes, short pause, 5 flashes, long pause, then it repeated over and over. Turns out that the second set of 5 flashes are the same duration as the first set. So that says it's flashing a 5 only, not a 55. Had me chasing my tail for a bit. Maybe that's what yours is doing. This thought totally occurred to me as well, but Im getting the impression hes getting a CEL indicating an active code. But definately worth a mention... Link to comment Share on other sites More sharing options...
jetpilotdc10 Posted September 2, 2015 Author Share Posted September 2, 2015 (edited) Definitely have a CEL, definitely 5 long followed by 5 short flashes. My other Loyale has 5 flashes with no CEL indicating no problems. As mentioned, the car does have some other issues so maybe once they're resolved this problem will sort itself out. Edited September 2, 2015 by jetpilotdc10 Link to comment Share on other sites More sharing options...
ihscout54 Posted September 3, 2015 Share Posted September 3, 2015 How many flashes are you getting befor the code? Link to comment Share on other sites More sharing options...
jetpilotdc10 Posted September 3, 2015 Author Share Posted September 3, 2015 (edited) Um, none? Is it supposed to? Doesn't say anything about that in the FSM and I've successfully resolved a few other codes it had. Oh, and the specification code is 5 on this car Edited September 3, 2015 by jetpilotdc10 Link to comment Share on other sites More sharing options...
