96 legacy replaced head gaskets heads were resurfaced new intake and exhaustgaskets. put it back together and it would not start. took it to local garage they replaced coil wires and plugs only cost 400. well they did get it started but it barely runs surely can noy drive .timing has been checked about 10 times . if i were a betting man that would be my guess. any help appreciated.
You might try checking the cam bolts.  Make sure you seated the cams in the correct position, and that you torqued down your cam bolts.
I would also check the  crank sprocket.  check that you are indeed using the timing mark on the very back of the sprocket and not the one up front of the sprocket.
Did you have the intake off the top of the engine?     Check the "crank sensor"  that it is connected.
  On 8/21/2015 at 3:05 AM, lstevens76 said:
Oh, check the crank sprocket for damage. Mine ran like that, but the crank sprocket was damaged. Replaced and problem solved.
X2
Broken reluctor tab on the crank sprocket will cause problems just like this. Make sure all 6 tabs are on the outer edge of the sprocket.
