bendecker Posted August 23, 2015 Share Posted August 23, 2015 Hi Gurus -- So, I crashed my '96 a while ago and have finally gotten around to fixing it. I need a passenger fender and a passenger door. I found a 1999 OBW at the local pic and pull and, of course, they won't let me bring my old door in to compare. I'm not too worried about the fender -- looks exactly the same (albeit a different color). The door looks very similar and the parts interchange person said the 199 would work on the 1996, BUT... with a note about how the window regulator might be different. Anyone have any tips as to if the door will just drop into the '96? As always, thank you for the advice! -Ben Quote Link to comment Share on other sites More sharing options...
987687 Posted August 23, 2015 Share Posted August 23, 2015 What door? The fronts will physically bolt up and work, not completely sure about the wiring, though. Just unhook the connectors on your car and see if they match the donor car. If it's a rear door it WILL NOT work. Sometime between 96 and 99 they added an extra little safety thingy toward the back of the door for extra strength in a crash or something. This will cause 99 back doors to not close on a 96, ask me how I figured this out Maybe it's a wagon vs sedan issue there, not sure. But I tried 99 OBW doors in a 96 leg. Quote Link to comment Share on other sites More sharing options...
bratman18 Posted August 23, 2015 Share Posted August 23, 2015 They'll fit, if that "thing" that 987687 speaks of is removed. Quote Link to comment Share on other sites More sharing options...
bendecker Posted August 23, 2015 Author Share Posted August 23, 2015 My bad. Front passenger door. I haven't pulled the wiring to see the connectors. Good advice there. Anyone else know if the wiring is the same? Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted August 24, 2015 Share Posted August 24, 2015 Doors should fit. With an Outback, it is the roof that was raised. Doors stayed the same. Can't see how the wiring could be different, or that much different. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 24, 2015 Share Posted August 24, 2015 Wiring changed in the drivers door I know. Dunno about the passenger door, but that really isn't hard to swap. The regulator may be different but that shouldn't matter because the window is the same shape. The regulator just moves it up and down. Make some accurate measurements and take pictures of the door and the profile inside the door jamb to compare. Quote Link to comment Share on other sites More sharing options...
987687 Posted August 24, 2015 Share Posted August 24, 2015 They'll fit, if that "thing" that 987687 speaks of is removed. No, they don't. The 99 back doors have a protrusion that makes them not fit on the 96. You can put early back doors on later cars, but not the other way around. Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted August 24, 2015 Share Posted August 24, 2015 (edited) the door, front passengere door will bolt on and close and latch. but the wiring is different. the 99 has a separate ''door lock'' button, the 96 does not. the 96 activates all the lkocks when ever the manual lock is operated. the 99 operates all the locks ONLY when the ''door lock'' button is operatewd. if the 99 door is manually locked, (at the door latch pull) only the passenger side front door will lock. but if you are willing ot swap the harness in the door, i bet the hardware would work the same, but this is just a guess. Edited August 24, 2015 by johnceggleston Quote Link to comment Share on other sites More sharing options...
