tanner93loyale Posted August 27, 2015 Author Share Posted August 27, 2015 On 8/27/2015 at 9:03 AM, MR_Loyale said: Will you be at WCSS this weekend? I will not be as I am going camping Friday to monday. But thanks for the help it is appreciated greatly! Hopefully I will get it worked out by tomorrow. Link to comment Share on other sites More sharing options...
superpoo93 Posted August 27, 2015 Share Posted August 27, 2015 On 8/27/2015 at 7:36 AM, MR_Loyale said: There is no actuator on the driver side front door. Did you mean the master switch panel? Sorry, you are correct...no actuator on drivers door..I meant the drivers side door lock switch(inside the door not the master panel). Link to comment Share on other sites More sharing options...
wagonist Posted August 28, 2015 Share Posted August 28, 2015 When you take off the inner door trim, screwed inside the door at the back of the bottom big hole in the frame. That is where the switch is. It's a black box which should have 3 or 4 wires hanging off it. 1 is permanent power, another is the unlocking signal, 3rd is locking signal. Some models have a 4th wire which goes to the "door lock" light on the dash. There is a linkage that goes upwards from this into the lock itself. when you lock/unlock the door with the latch or the key, it pushes/pulls this linkage. I'd 1st check that this linkage hasn't come off. Link to comment Share on other sites More sharing options...
