The Scooby Posted May 28, 2004 Share Posted May 28, 2004 ok i got my DFAV weber which im putting on my car tomarrow. i got the adapter i needed, just need to get suds and nuts to bolt the weber onto the adapter. oh and i only paid $33.60 for the adapter, rather then $48 since i work at Aaron's auto wrecking... another plus of this job. but my questions are: do i need to ad anoth throttle return spring other then the one on it? how do i hook up the stock EA82 throttle cable onto it? thats all i can think of right now. Thanks, Shean Link to comment Share on other sites More sharing options...
heep70 Posted May 28, 2004 Share Posted May 28, 2004 I had to add another return spring on mine and the throttle cable hooked right up using the same mounting spot on the manifold. I had to cut the end off to get it fixed to the carb. Here is a thread w/ pics. http://www.ultimatesubaru.org/forum/showthread.php?t=13741&highlight=weber Link to comment Share on other sites More sharing options...
TomRhere Posted May 28, 2004 Share Posted May 28, 2004 http://www.ultimatesubaru.org/forum/showthread.php?t=16173 Knew it was here, but took time to find it, was back quite afew pages. Link to comment Share on other sites More sharing options...
chef_tim Posted May 28, 2004 Share Posted May 28, 2004 If you use the universal cable mounting kit, don't cut the end of the cable. Just take a propain tourch to it. It is lead and will leave just enough to keep the cable from fraying. Tim Link to comment Share on other sites More sharing options...
The Scooby Posted May 28, 2004 Author Share Posted May 28, 2004 ok, but how do i mount the throttle cable onto the linakge? and rather then buying that thing from redline i can make one in like 20 minutes at school for free, except for the time it takes to make it. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 28, 2004 Share Posted May 28, 2004 There's more to the redline kit than just that bit of metal. Buy the kit and you will understand. It's only $20. GD Link to comment Share on other sites More sharing options...
The Scooby Posted May 28, 2004 Author Share Posted May 28, 2004 ya, $20 i dont have. so looks as if im going to go buy some JB Weld to plug that whole in the intake where the coolant goes up into the stock hitachi. Shean Link to comment Share on other sites More sharing options...
The Scooby Posted May 28, 2004 Author Share Posted May 28, 2004 well got it mounted, and everything running right, i just need to get a air cleaner for it. i got a linkage kit through Autosport its made by EMPI part# MB/430602 it replaces the stock weber linakge and makes it much easier to adapt the stock cable onto the carb, i just cut off the lead, and put it on. havent gone driving yet, but it seems to run smoother at adle by quite a bit, and revs faster. ^ and there's the new linkage kit from EMPI, was only $10, and well worth it. Later, Shean Link to comment Share on other sites More sharing options...
