Hogan029 Posted September 1, 2015 Share Posted September 1, 2015 hi all. Just wondering if you can name this part. I have a EJ25 USA version which this is on and a JDM EJ25 which doesn't. I am thinking of swapping the U.S. Intake on the JDM as I have a US wiring harness. Thanks all! Link to comment Share on other sites More sharing options...
lstevens76 Posted September 1, 2015 Share Posted September 1, 2015 I believe that is the purge control solenoid. Japan had different emissions requirements than the US and as such different emissions systems. Base the intake and drivers side cam sprocket/crank sprocket on what computer you are using not the engine. Link to comment Share on other sites More sharing options...
Fairtax4me Posted September 1, 2015 Share Posted September 1, 2015 Evap canister purge solenoid. Agreed. Use your US intake and wiring. Check the reluctor teeth on the back of the drivers side intake cam sprocket and crank sprocket. Swap your originals on if they're different. Link to comment Share on other sites More sharing options...
Hogan029 Posted September 1, 2015 Author Share Posted September 1, 2015 Awesome thanks for the replies! Link to comment Share on other sites More sharing options...
