Tmt Posted September 1, 2015 Share Posted September 1, 2015 Hi all. This is the first time I have posted here. My mother in law has a 2001 forester and wants to upgrade to a power front seat. Is this a possibility? Or would it be incredibly costly? Is there some aftermarket option? She loves her car but arthritis is her hands are making it hard for her to grab that lever. Thanks in advance. Link to comment Share on other sites More sharing options...
forester2002s Posted September 1, 2015 Share Posted September 1, 2015 (edited) First, check under the front carpet, to see if the wiring harness is already in place for heated-seats. If so, that makes your project much simpler. Then, I would search around for used heated-seats at junk-yards. You may find a wrecked car with almost new seats. Good luck. EDIT: Just reread the original post. You want to instal Power-seats, not Heated-seats. That's a 'different kettle of fish'. Edited September 2, 2015 by forester2002s Link to comment Share on other sites More sharing options...
Rooster2 Posted September 2, 2015 Share Posted September 2, 2015 First, check under the front carpet, to see if the wiring harness is already in place for heated-seats. If so, that makes your project much simpler. Then, I would search around for used heated-seats at junk-yards. You may find a wrecked car with almost new seats. Good luck. I put heated seats into my 99 OBW. Don't think power seats were offered back then. I could not find wiring under the seat for a heated seat, so got the 2 front seats, and the wiring as well. Look first for wiring where the power seat control would be located. Forester seats sit taller then Legacy seats, so you are most likely to find seats that fit from another Forester. Link to comment Share on other sites More sharing options...
john in KY Posted September 2, 2015 Share Posted September 2, 2015 WARNING. If whatever seats you end up with have YELLOW wires in the harness, these are for the airbags so don't apply power to them just to be on the safe side. Link to comment Share on other sites More sharing options...
Dj7291993 Posted September 3, 2015 Share Posted September 3, 2015 I don't think they were an option for that generation of Forester, so you'd have to see if you can fit seats from a new one. I'm not sure if the later ones will bolt up or not. Link to comment Share on other sites More sharing options...
