oldskoolNC Posted September 2, 2015 Share Posted September 2, 2015 Hi, Im new to the site, but I am really in need of some advice from folks who know their Subarus! I have a 1986 Subaru GL, 1.6, carb. and it has developed a problem. It started a couple of months ago. My husband would drive it to work early in the morning when it was cool, and would make it there fine. However on his way home in the heat of the day it would stall out about 10 minutes into the drive. If you let it sit for about 45 minutes it would start again. My hubby is NOT mechanical, so with a book and advice and process of elimination I have done the following.. Tried to rule out vapor lock- replaced fuel filter, seperator, and fuel pump replaced igniton coil replaced plugs,wires,rotor and distrib. cap. It is still doing it. I have been told it may be a sensor, but can't find an engine cooling sensor if there is one. Any ideas are appreciated. Mechanic isn't in the budget and we are down to one car now. Thanks! Quote Link to comment Share on other sites More sharing options...
oldskoolNC Posted September 2, 2015 Author Share Posted September 2, 2015 Also forgot to mention, all fluid levels are fine and fan works perfectly. Quote Link to comment Share on other sites More sharing options...
naru Posted September 2, 2015 Share Posted September 2, 2015 Check for spark next time it quits. Kinda sounds like the carb might be flooding though. Check the fuel level in the carb sight glass(might need a mirror) Fuel level should be in the middle. Quote Link to comment Share on other sites More sharing options...
