94 legacy manual awd brakes locking up
I'm having issues with my wagon, my right rear wheel keeps locking up. It will drive fine for 5 or 10 minutes, then you can feel it start it grab then it locks down completely and drags the tire. Tried replacing the calipers and disconnected the abs, not sure what else to do. Any ideas?
Does it release on its own, or do you crack a bleeder ? I'm thinking possibly  a crushed (steel) or crushing(rubber)brake line that allows pressure in but will not freeflow back , after a few pumps of the pedal pressure builds in the caliper and it can't release ?
Actually yes. I blew my rear main seal a couple of months ago. Tried to haul it to my garage on a dolly, didn't think about it being awd. Screwed up my transmission. Since then I've replaced the rear main seal, clutch, tranny, drive shaft, rear differential, and rear calipers.
tranny? and rear diff ?
those 2 MUST have the same final drive ratio or you will get torque bind.
next time the wheel locks up, chock the other wheels and carefully jack that corner of the car up - see if the binding is released. Or, see if you can do slow, tight circles in a parking lot smoothly.
Edited by 1 Lucky Texan
