annoying fuel pump issue
On the spfi cars the fuel pump will not crank unless the engine is turning. If you put it in self check mode the pump will cycle/pulse key on engine off.
Flakey pump operation could be a bad relay or harness issue. Check the pump ground. I had an ecm once that would not trigger the pump. The driver circuit inside the ecm had failed I suppose.
