Nowhereman Posted September 4, 2015 Share Posted September 4, 2015 (edited) Does anyone know where to get head studs to replace the head bolts in a ea82t Edited September 5, 2015 by Nowhereman Link to comment Share on other sites More sharing options...
Caboobaroo Posted September 5, 2015 Share Posted September 5, 2015 No one makes them. Last quote I recieved from APR for my ER27 was almost $800! Link to comment Share on other sites More sharing options...
Nowhereman Posted September 5, 2015 Author Share Posted September 5, 2015 That's nuts, I don't want to put bolts back in after all the work I just did, Link to comment Share on other sites More sharing options...
Tom0 Posted September 5, 2015 Share Posted September 5, 2015 could try going to a machine shop to make some up? I would think (tentatively) that they could do it cheaper then that. Link to comment Share on other sites More sharing options...
That_rx Posted September 24, 2015 Share Posted September 24, 2015 On 9/4/2015 at 11:58 PM, Nowhereman said: Does anyone know where to get head studs to replace the head bolts in a ea82t if you are talking head bolts I believe Subaru dealership sells them. Link to comment Share on other sites More sharing options...
coxy Posted September 24, 2015 Share Posted September 24, 2015 (edited) Try and find a catalogue that gives dimensions from either ARP or SPS and then look and see what you could make work. I have in the past modified a Nissan Z 18 Turbo to use Ford Windsor 289 bolts and used Toyota Supra ARB studs in a Drag Lancia Delta Integrale engine in a 1200 Datsun ute so anything is possible, though you may have to drill out the head bolt holes in the heads and block if the diameter is bigger. There will be something that will work just have to do the research. Edited September 24, 2015 by coxy Link to comment Share on other sites More sharing options...
