Aluxes Posted September 5, 2015 Share Posted September 5, 2015 Anyone know what the stock roof rack weight limit is for a 97 OBS? I want to get a Thule case and dont want to go over the weight limit. Link to comment Share on other sites More sharing options...
Rooster2 Posted September 5, 2015 Share Posted September 5, 2015 I would bet there is no stock roof rack weight limit listed anywhere. My guess is not much more then 100 poinds max. Those roof rails, and how it is affixed to the roof don't seem very strong to me. Link to comment Share on other sites More sharing options...
jp98 Posted September 5, 2015 Share Posted September 5, 2015 The owners manual says only 100 lbs, I tried to read the sticker on my rack but it is so sun bleached that it is unreadable. Link to comment Share on other sites More sharing options...
Aluxes Posted September 8, 2015 Author Share Posted September 8, 2015 The owners manual says only 100 lbs, I tried to read the sticker on my rack but it is so sun bleached that it is unreadable. 100 pounds? Wow, I thought it might be a little more than that. Well guess I should get an owners manual! Thanks for the answer though! Link to comment Share on other sites More sharing options...
ocei77 Posted September 8, 2015 Share Posted September 8, 2015 I'd say you can safely use more weight than this. I do some small contracting work and I regularly carry various loads of plywood,sheetrock and lumber on top. Not trying to carry a new deck's worth but I am sure I carry a lot of 150-200 lbs loads, with no ill effects. This on a 96 OB. O. 1 Link to comment Share on other sites More sharing options...
porcupine73 Posted September 12, 2015 Share Posted September 12, 2015 Right on I think around 100 lbs is what I've seen in my Legacy manual too. I think that rating isn't so much that the rack can't hold more than that, I mean it can definitely support more than that as a static load. I think they keep the weight down low because of (1) emergency handling might get crazy with too much load up there, and (2) in an accident they probably don't want to chance the rack ripping right off the roof. Link to comment Share on other sites More sharing options...
AdventureSubaru Posted September 12, 2015 Share Posted September 12, 2015 x2. If the weight is displaced, the rack will hold double that, But if 200 pounds is in one of those cargo carriers and you rear end someone at 35+ you may be firing a torpedo off the top of your car. Link to comment Share on other sites More sharing options...
