jono Posted September 5, 2015 Share Posted September 5, 2015 just looking at a combo indicator / hazard / high beam switch from an early EA82 and thinking it looks similar to an EA81 combo switch. Has anyone adapted something later into EA81 steering column mounted combo switches ? These EA82 switches have a weird inbuilt flasher can functon which would screw with the EA81 flasher can installed already .... but, there are some genius's out there .... Link to comment Share on other sites More sharing options...
wagonist Posted September 7, 2015 Share Posted September 7, 2015 Why are you looking at swapping? Your's is dead and need a replacement? I remember a mate 20 years ago having his flashers die on his 85 model and managed to find the resistive bit of wire in question on the circuit board. If you could cut & intercept that, or else bypass the flasher in the EA81, that might work. Link to comment Share on other sites More sharing options...
jono Posted September 7, 2015 Author Share Posted September 7, 2015 got a pair of EA82 1985 model combo switches, and no EA82 to use them in, saw the resemblance and thought worth asking. Task for a day of empty boredom I think 1 Link to comment Share on other sites More sharing options...
jono Posted September 8, 2015 Author Share Posted September 8, 2015 and what got my attention - the white plastic indicator cancel doo hickeys - wondered if they interchanged ! Link to comment Share on other sites More sharing options...
coxy Posted September 13, 2015 Share Posted September 13, 2015 and what got my attention - the white plastic indicator cancel doo hickeys - wondered if they interchanged ! Ah the part if it was available would be fitted to every subaru over twenty years old, You could always look into one of those TSD (Time Speed Distance) fancy Flasher cans Harleys and a few other things use them and they take care of cancelling the blinkers by themselves, That or a bloody annoying buzzer whenever the blinkers are on. Link to comment Share on other sites More sharing options...
jono Posted September 13, 2015 Author Share Posted September 13, 2015 ahh my 17 years as a non cancelling blinker owner - the fingers are well trained ... maybe i should be making it work in a Brumby ? I am pretty sure that new combo switches are available genuine, just the hock shop would be stocking a lot of left nuts Link to comment Share on other sites More sharing options...
