Uberoo Posted September 9, 2015 Share Posted September 9, 2015 So I have an 83 mazda RX7 that I would like to put a phase 1 ej22 in.While I am at it there is a few issues with the front suspension I would like to address. 1: despite the car's sporty nature it has truck type recirculating ball steering which is sloppy and lacks steering feedback. 2: the entire front suspension is weak and failure prone when abused in gravel or rough roads like those around here. 3.The car has a 4x110mm lug pattern on the wheels,and the cars with 4x110 are : old rx7's and 626's.Neither option came with 14+ wheels.My RX7 is rocking the 13" alloy wheels it came with,but to get good tires I would need to step up to atleast a 15" wheel. To address all those problems I was thinking of just getting a 89-94 legacy or 92-94 imp and swap its front crossmember,engine/transmission,and rear brakes into the RX7.No, the awd is not being swapped. The front track width on a lego is a mere 0.9" wider than the rx7,and the lego has rack and pinion steering and rally proven suspension. While in stock form the rx7 has a respectable 6.1" of ground clearance, I would feel a bit more secure driving on the roads around here with a little more ground clearance and some strong and durable LT tires.The smallest LT tires I can find are about 27" tall needing about a 2-3" lift to clear them.With that much lift, I bet it would look pretty sweet dressed up like an old safari rally car: like this: or like this: so with that being said is there any practical differences between lego and imp front suspension that would make fitting 27" tires easier? Link to comment Share on other sites More sharing options...
Fairtax4me Posted September 9, 2015 Share Posted September 9, 2015 You'll need 96-99 Outback struts to fit 27" tires. Stock outback size 205/70/15 (26.5" I think) won't fit normal Legacy struts. The outback struts have a higher spring perch which gives extra room to fit the larger tire. There's just something so strange, wrong, and cool about a 60's mustang running 6lug Toyota wheels! Makes you wonder what else is going on underneath that body. Link to comment Share on other sites More sharing options...
Uberoo Posted September 9, 2015 Author Share Posted September 9, 2015 (edited) 351,4 speed manual,spooled toyota rear axle,and from a pic I saw of it without the wheels on-coilovers in the rear,and springs/shock combo in the front.looked like toyota hubs/brakes connected to mustang suspension up front. Edited September 9, 2015 by Uberoo Link to comment Share on other sites More sharing options...
