DavidHenry Posted September 10, 2015 Share Posted September 10, 2015 My 2000 Subaru outback engine locked up at 2:00 in the morning at 75 MPHgoing south on I-35 close to Dallas, Texas.All four wheels stopped turning...I had the clutch in within seconds but notbefore I nearly had a heart attack. Lucky I had a manual transmission. I brought the car home to San Antonio on a trailer. In the next few weeks I found another EJ25 engine at a local Pick andPull that was in a 2001 Legacy sedan with an automatic transmission. Upon taking the engine home I removed the oil pan and heads and checked and cleaned everything. Replacing seals and timing belt, spark plugs, spark plugwires, head gaskets, and clutch. . I used my original fly wheel and intake manifold and all engine wiring.When I started it I had a bad miss. #3 was not firing even though it had plenty of spark and compression. And it was sucking fuel. I had to keep itABOVE 2000 rpm to keep it running well enough to go around the block. I spent several days testing everything. It had an engine code of 340 and 341. Cam shaft sensor error so I at first thought I had made a mistake in thevalve timing when I changed the belt. But after I double checked it I could notfind a problem. I changed the sensor, made no difference. I checked the circuit for continuity. All was ok in the wiring, I checked and electro cleaned the wiring harness connectors.Still no improvement. Finely I took it to a well respected speed shop that is here in the city for a diagnostic evaluation as half of the cars they modify are Subaru’s. After half a day driving the tech crazy they gave up and suggested I must have mechanical problems in the left head #3 and 4... I took it home and started studying everything I could find on the web and talking to every Subaru Tech I could find...and then I heard a story aboutsomeone else who had this problem...Seems that Subaru uses a different camsprocket for the cars with manual transmissions then they do for ones withautomatic transmissions. Different number and position of the magnets embeddedin the back of the sprocket. I removed the one from my old engine and it hadtwo magnets about 90 degrees apart. I removed the one from this replacementengine that had previously been in the car with the automatic transmission andit had seven! I changed the sprocket and replaced the timing belt and the engine started and ran on all cylinders and stopped guzzling fuel. Ran smooth and sweet. The computer, Engine Control Unit (ECU) for the Subaru with the manualtransmission is programmed differently than the one for the automatictransmission. I had read many posts about engine swaps but no one in any of these posts have mentioned this very important piece of information. And the timing sprocket on the crankshaft is different also. The one for the manual transmission has many teeth while the one for the automatic has onlysix. So any of you who are contemplating swapping engines take note and check your driver’s side cam sprocket and your crankshaft sprocket before youspend a week and a lot of money chasing this problem. Link to comment Share on other sites More sharing options...
AdventureSubaru Posted September 10, 2015 Share Posted September 10, 2015 It's been talked about a few times on here, but the more people are reminded the better. The general rule is to just keep the cam and crank sprockets to match the car as you go. Sorry it took so much frustration to discover that but glad you've got the car back on the road again. Link to comment Share on other sites More sharing options...
idosubaru Posted September 10, 2015 Share Posted September 10, 2015 It might be deserving of a tip or submission but it's well known to Subaru people and has been mentioned many times here over the years: http://www.ultimatesubaru.org/forum/topic/143366-crank-cam-sprocket-differences/ http://www.ultimatesubaru.org/forum/topic/99698-help-ej22-to-ej25-swap-wont-start/ http://www.ultimatesubaru.org/forum/topic/151051-2001-ej22-into-a-2003-legacy/ http://www.ultimatesubaru.org/forum/topic/141340-2002-outback-engine-swap/ http://www.ultimatesubaru.org/forum/topic/95420-2003-outback-wont-start-after-engine-swap/ http://www.ultimatesubaru.org/forum/topic/139190-ej253-ej251-99-forester/ Link to comment Share on other sites More sharing options...
