TypeOPositive Posted September 10, 2015 Share Posted September 10, 2015 (edited) I tried to search this as I feel like it's something that would have been easy to find, but what I found was mainly about what tires you can bolt on to certain levels of lift. My legacy is bone stock, suspension and otherwise. The wheel FAQ didn't say much about fitment issues. I feel like in my searching I've found that stock outback rims could work, but I'd have to go with a tire with less height, like a 205/55-16. According to the tire size calculator on the miata site, those have about .7 in in diameter. If the limiting factor is the strut tower, wouldn't a modest offset help prevent the wheel from hitting that?? I'd like to get a slightly bigger tire for winter because as it is, i scrape the very bottom of my hitch where I'm driving most often (lots of sharp incline / declines.) I believe I've read that the WRX rims will fit, but I don't need anything fancy. A set of steel rims would work fine. Is it going to be more realistic for me to fit 15 in rims over 16's? Again, I'm sorry if this has been asked before. Edited September 10, 2015 by TypeOPositive Link to comment Share on other sites More sharing options...
AdventureSubaru Posted September 10, 2015 Share Posted September 10, 2015 The rims will fit, but your tire size will be the limiting factor. If your car is dragging that much, your car would be a great candidate for a set of outback struts. You can swap the whole assemblies from a 96-99 outback for a couple inches of suspension lift and then clear a 27 inch tire for some good ground clearance. Link to comment Share on other sites More sharing options...
TypeOPositive Posted September 10, 2015 Author Share Posted September 10, 2015 I was hoping for something more modest, around 1-2 inches instead of 3 or so. Link to comment Share on other sites More sharing options...
Rooster2 Posted September 10, 2015 Share Posted September 10, 2015 What size tires and wheels does your car have on right now?? Link to comment Share on other sites More sharing options...
TypeOPositive Posted September 10, 2015 Author Share Posted September 10, 2015 185 70 - r14. Will I need the entire assembly from an Outback to maintain correct geometry? 1 Link to comment Share on other sites More sharing options...
Greenbaru Posted September 11, 2015 Share Posted September 11, 2015 After Lifting my 98 Outback BACK to stock it looked great and allowed a larger tire- both asthetically and functionally.. The stock springs on your Soob (what year) might have settled substantially. Subaru springs are less than adequate. An aftermarket spring increasing the rate would resist the vehicles saggy stance. Link to comment Share on other sites More sharing options...
TypeOPositive Posted September 11, 2015 Author Share Posted September 11, 2015 As the title states, I've got a '97. I'm really trying to stay stock, as the warranty on my drive shafts doesn't cover lifted vehicles. Would new kyb struts and stiffer springs give more height without making modifications? Link to comment Share on other sites More sharing options...
AdventureSubaru Posted September 12, 2015 Share Posted September 12, 2015 (edited) They would only give more height if your current struts are blown. Options would be 1 inch hub spacers which would let you clear a slightly larger tire. Go up a tire size or two as is. Use a measuring tape to see how tall and wide a tire you can stuff in there without rubbing. Outback struts/springs - far and away your best option. Gives about 2 inches right away and will give you a couple more depending on tire size and can clear up to a 28 inch tire if you so choose. - regardless of axle warranty. If they are good axles they will last a long time. If they are chinese made, you'd be swapping them every 3-6 months anyway until you buy good ones. And remember that axles are the same for both legacy and outback and that outback struts are quite stock. I don't see how anyone could hassle you on that as you are still within stock specifications and OEM parts. Strut top spacers which would give you height but not clear bigger tires. You can cut up to 3/8 inch HDPE spacers without knocking the stock bolts out. Up to 1 inch if you replace the strut top bolts with longer ones. And then any size after that in steel lift brackets. Edited September 12, 2015 by AdventureSubaru Link to comment Share on other sites More sharing options...
