Mikevan10 Posted September 10, 2015 Share Posted September 10, 2015 I have searched the forum and I did find some threads that touched on this topic but I still have questions.... I am planning to replace the original/stock radio/cassette player on my 1992 Legacy sedan. The original unit's faceplate measures about 72 mm in height. I am planning to install what I believe is called a single DIN receiver which I am pretty sure is closer to 50 mm in height. The guy at Crutchfield said the new unit will mount just fine using the existing, stock radio brackets. Does this sound correct? And, if so, won't I be left with an unsightly gap below the new receiver? My other question is regarding the speaker wiring. Would the 1992 Legacy have the setup where front and rear speakers on each side share a common ground? If so, is this something I will need to correct (i.e.rewire so that each of the four speakers has a dedicated ground)? Thanks as always, Mike V. Quote Link to comment Share on other sites More sharing options...
