legacy93wagon Posted September 12, 2015 Share Posted September 12, 2015 Hello. thanks for stopping by. First I have spent a good hour searching and digging before I posted this thread."pulse" and other terms I could think of brought up a lot of fuel system stuff but not what I feel is going, IE please hold your tongue for " do your own research" type replies. We are a community after all :0D The real thread starts here: 1998 Subaru Legacy Wagon 2.5 AWD automatic trans. I experience a pulse, " whoosh, whoosh whoosh" sound and feeling that picks up and slows down as the vehicle's speed does ( not engine speed, but vehicle speed) It felt to me like it was coming from the front. Things I have done / checked: 1. New tires and balanced ( needed them anyways did not fix issue) 2. checked boots at wheels , Front + back, No rips I could see 3. Checked boots at trans ( front axles ) no visible rips Unrelated recent maintenance since : oil chance fuel filter replaced Air filter service ( K & N type) Any thoughts/ Questions/ links / other threads related would be greatly appreciated Link to comment Share on other sites More sharing options...
johnceggleston Posted September 12, 2015 Share Posted September 12, 2015 does the sound get louder or quieter when you turn, at speed, like an entrance ramp? try turning both directions. it may be a front wheel bearing. 1 Link to comment Share on other sites More sharing options...
legacy93wagon Posted September 12, 2015 Author Share Posted September 12, 2015 does the sound get louder or quieter when you turn, at speed, like an entrance ramp? try turning both directions. it may be a front wheel bearing. "you have reached your quota of positive votes for the day" I will pay close attention to these situations this weekend and report back. Link to comment Share on other sites More sharing options...
legacy93wagon Posted September 15, 2015 Author Share Posted September 15, 2015 does the sound get louder or quieter when you turn, at speed, like an entrance ramp? try turning both directions. it may be a front wheel bearing. ok, at about 70 mph the noise does get louder on turns ( I80) Noise seems slightly louder when going to the right more that the left but louder either way vs straight. Either when on ramps there was no difference, or was so worried about being run over I was unable to notice. Off to read up on wheel bearing until I get your response. Thanks. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted September 15, 2015 Share Posted September 15, 2015 all tires the same brand/model/size and close in wear? they must be. does the car jerk or feel like it is resisting tight maneuvers in parking lots? can it idle (or very little gas) thru tight circles on dry pavement smoothly? have the brakes been well maintained? 1 Link to comment Share on other sites More sharing options...
legacy93wagon Posted September 16, 2015 Author Share Posted September 16, 2015 all tires the same brand/model/size and close in wear? they must be. does the car jerk or feel like it is resisting tight maneuvers in parking lots? can it idle (or very little gas) thru tight circles on dry pavement smoothly? have the brakes been well maintained? All tires are new, same brand, same size same tread pattern, Have not put in the fwd fuse to try it like that. car does not jerk, parking lot maneuvers seem fine no extra gas is needed. Brake system, not sure, new to me car so other than brief visual inspection brakes have not gotten any attention from me Link to comment Share on other sites More sharing options...
legacy93wagon Posted September 16, 2015 Author Share Posted September 16, 2015 wowza! wheel bearing looks like a beast of a job, and requires some special tools :0/ replacing whole wheel hub with good bearing a method back yard mechanics often go ? Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted September 16, 2015 Share Posted September 16, 2015 yeah, bearing assemblies didn't come in umtil 2005 or so, depending on model. there are 'hub tamers' and various kits you can buy or rent from some parts stores. an intermediate approach would be to take your new bearings, hub if needed, and your old knuckle to a shop and have them press-out old, then press-in new, bearings. 1 Link to comment Share on other sites More sharing options...
