subdude Posted September 15, 2015 Share Posted September 15, 2015 Working on 1994 Subaru Loyale Wagon 1.8 . Haynes Manual calls for 80-97 in. lbs. and Chilton/All Data calls for 4.3 - 5.1 ft. lbs. for the two retaining bolts for cam seal. Which is correct? Thanks! Quote Link to comment Share on other sites More sharing options...
idosubaru Posted September 15, 2015 Share Posted September 15, 2015 I'd work towards getting an FSM, they can be found free online, then you have everything you need in the future. i doubt i've ever used a torque wrench on those, they're not a big deal and neither of those numbers will strip the threads. Quote Link to comment Share on other sites More sharing options...
subdude Posted September 15, 2015 Author Share Posted September 15, 2015 Guess we ran out of patience and torqued it to 70 in. lbs. thinking that would be a good compromise but one of the bolts spun at 70 and when we removed it , it appears to have a thread repair attached to it. Any ideas on what size thread repair we should use? It appears to be a 6mm bolt. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted September 15, 2015 Share Posted September 15, 2015 M6 x 1.00 Often times on those EA/ER engines - the bolt holes are much deeper than the original bolts. So you can get a longer bolt and just insert it down there to grab the deeper threads. I like to chase it with a M6x1.00 tap first to clean it all up. I have no clue how many times I've done that. Find some longer M6x1.00 bolts that are longer and give it a shot, use washers as spacers under the head if they're too long or cut the threads shorter and chase the ends with a die to smooth out the cut threads. 1 Quote Link to comment Share on other sites More sharing options...
idosubaru Posted September 15, 2015 Share Posted September 15, 2015 (edited) But yes - if they're totally hosed and not enough threads - just repair it. Could probably even find a larger size bolt to tap too - standard size just a wee bigger or thread repair inserts should work fine. Ring angle drill attachment if it's in the vehicle. put the drill bit in a vice and WAAAAIL it with a hammer and it'll shear off to make it short enough to fit in front of the engine with a right angle drill or attachment. be careful - the sheared of drill bit will fly and bounce all over the garage - where goggles and don't hit anything breakable. Edited September 15, 2015 by grossgary Quote Link to comment Share on other sites More sharing options...
subdude Posted September 15, 2015 Author Share Posted September 15, 2015 Thanks so much for the help. We'll hunt up a longer bolt before digging up the goggles! Just curious, have you ever used Loctite Thread Repair? Quote Link to comment Share on other sites More sharing options...
rdweninger Posted September 17, 2015 Share Posted September 17, 2015 4 ft/lb would be 48 in/lb 5 ft/lb would be 60 in/lb At 70 in/lb, you were approaching 6 ft/lb ... which compared to 4 is 150% of max torque. Not sure what FSM calls for. I don't own an in/lb torque wrench ... that's just snug + Quote Link to comment Share on other sites More sharing options...
idosubaru Posted September 17, 2015 Share Posted September 17, 2015 Thanks so much for the help. We'll hunt up a longer bolt before digging up the goggles! Just curious, have you ever used Loctite Thread Repair? no, not really. i'm sure I've put locktite on a questionable bolt before - but i always address bad threads first and consider this extra insurance. it would probably be fine for somethign benign like a cam cap though. Quote Link to comment Share on other sites More sharing options...
subdude Posted September 18, 2015 Author Share Posted September 18, 2015 Thanks for the replies and helpful info. Just got back to the 'roo today and cut a longer 6mm x 1 bolt so that it was about 1/4" longer than original. After chasing the threads with tap all went well with new bolt and a lock washer... THANKS GARY! Thanks too for info about free FSM downloads. We actually ended up finding workable links here on USMB for 1989 models. BTW the torque values in the FSM were identical to Chilton's/AllData at 4.3-5.1 ft. lbs. Not really sure what the Haynes is all about at 80-97 inch pounds, but we ended up at 60 inch pounds for all 4 bolts. The Loctite thread repair is actually an epoxy and release agent for "creating" new threads that are supposed to support up to 128 foot pounds when cured...I would suspect it is about the equivalent of a combination of JB Weld and petroleum jelly! Here is the link at NAPA: http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Thread-Repair-Chemical-Loctite-Form-A-Thread/_/R-NCB28654_0195609250. Quote Link to comment Share on other sites More sharing options...
