beau83 Posted September 16, 2015 Share Posted September 16, 2015 I want to swap the EJ20 Engine and 5speed Manual Gearbox in my Subaru Outback/Liberty Wagon 1999 model, it has selective AWD. I want to replace it with an EJ20 Engine from a Subaru RX Impreza Wagon 1998 model, 5 speed Gearbox with only 2WD. I have added some photos of both 'main engine wiring harnesses' which might help.. The 99' OUTBACK/LIBERTY main engine harness has "1x14 pin(brown) + 1x19pin(white)" plugs, while the 98' RX IMPREZA engine has "1x6pin(white) + 1x8pin(grey) + 1x16pin(grey) plugs. Im wanting to know if there is a 'conversion plug kit' available for this swap or do i need to get it re-wired? I cant swap engine harnesses because most of the plugs on the other end are different. I also noticed that the ECU plugs(located on passenger floor) are also different on these 2 models, any information/help with this conversion would be great. Also how do i confirm what size the engine is 2.0l-2.2l- 2.5l? They are both EJ20 engines and im pretty sure they are both Australian models (i bought them both in Australia) Thanks in advance BEAU83 I am putting a EJ20 engine and gearbox out of a "1998 SUBARU RX IMPREZA wagon" into a "1999 SUBARU OUTBACK/LIBERTY wagon".... I have tried changing the Intake Manifolds with Engine Wiring still attached but the Intake Manifolds are different in size. Attached Thumbnails 1 Link to comment Share on other sites More sharing options...
TOONGA Posted September 16, 2015 Share Posted September 16, 2015 You should start a thread on AUsubaru http://www.ausubaru.com As you are in Australia There is no conversion kit as such but the swap can be done. I'm sure you will not only get the help you need but you may even find someone who can help you with the whole swap. Good luck with it all TOONGA Link to comment Share on other sites More sharing options...
