EJ20 SUBARU RX IMPREZA 98' ENGINE,MODS TO PUT INTO A SUBARU OUTBACK/LIBERTY 99'
beau83
I want to swap the EJ20 Engine and 5speed Manual Gearbox in my Subaru Outback/Liberty Wagon 1999 model, it has selective AWD. I want to replace it with an EJ20 Engine from a Subaru RX Impreza Wagon 1998 model, 5 speed Gearbox with only 2WD. I have added some photos of both 'main engine wiring harnesses' which might help.. The 99' OUTBACK/LIBERTY main engine harness has  "1x14 pin(brown) + 1x19pin(white)" plugs, while the 98' RX IMPREZA engine has "1x6pin(white) + 1x8pin(grey) + 1x16pin(grey) plugs. Im wanting to know if there is a 'conversion plug kit' available for this swap or do i need to get it re-wired? I cant swap engine harnesses because most of the plugs on the other end are different. I also noticed that the ECU plugs(located on passenger floor) are also different on these 2 models, any information/help with this conversion would be great. Also how do i confirm what size the engine is 2.0l-2.2l- 2.5l?  They are both EJ20 engines and im pretty sure they are both Australian models (i bought them both in Australia)
        Thanks in advance
        BEAU83
I am putting a EJ20 engine and gearbox out of a  "1998 SUBARU RX IMPREZA wagon"   into a   "1999 SUBARU OUTBACK/LIBERTY wagon"....
I have tried changing the Intake Manifolds with Engine Wiring still attached but the Intake Manifolds are different in size.
  • post-59879-0-17883600-1441686056_thumb.j
  • post-59879-0-53646000-1441686071_thumb.j
  • post-59879-0-42757000-1441686091_thumb.j
  • post-59879-0-56390300-1441686124_thumb.j
  • post-59879-0-33290000-1441686143_thumb.j
  • Like 1
