The Dude Posted September 16, 2015 Share Posted September 16, 2015 What parts are required to perform a valve adjustment on a 2006 Forester? Valve cover gaskets? Spark plug gaskets while I'm in there? Any "tips" on doing the adjustment? Thanks. Quote Link to comment Share on other sites More sharing options...
ccrinc Posted September 17, 2015 Share Posted September 17, 2015 Courtesy of Trey from Cobb Tuning: T Great write-up Stimpy. Here is how we find the position of each cylinderto set lash, which is just slightly different than what Stimpy haswritten. Setting valve lash on 2.5L SOHC.1) Remove the radiator overflow bottle.2) Remove the driver's side section of the timing belt cover (just 3 bolts) to expose the driver's side camshaft sprocket.3) Remove valve covers and necessary components (we typically pull air filters/boxes and the windshield washer bottle to get better access.)4) With a 22mm socket and long breaker bar, rotate engine until the ARROW on the driver's side camshaft sprocket is at 12 o'clock (UP). Set the valve lash on the #1 cylinder when camshaft sprocket is in this position.5) Rotate engine through two revolutions and set ARROW on the camshaft sprocket at 6 o'clock (DOWN). Set the valve lash on the #2 cylinder.6) Rotate engine again 2 revolutions and set the arrow on the camshaft sprocket at 3 o'clock (RIGHT) (standing in front of engine bay). Set the valve lash on the #3 cylinder.7) Rotate engine again 2 revolutions and set the arrow on the camshaft sprocket at 9 o'clock (LEFT). Set the valve lash on the #4 cylinder.8) Put everything back together and test drive. This might be more exactif for some reason you can't tell the exact position of each cylinder.Plus, it makes it easier than pulling all the timing covers off. Werotate the engine 2 rotations to give the cam a full turn (it turns 1/2speed of the crank) and recheck the lash on the cylinder we just setbefore going to the next. It's not a requirement, but it's a good QAstep. Other than that, the lash adjustments Jon (Stimpy) wrote were deadon. Make sure you keep the feeler gauge on the same "plane" as the topof the valve. If you have it in at an angle, you might set the valvelash too high and it'll be noisy. Take your time, and you'll get itright. It is definitely something you begin to get a feel for afteryou've done it a few (hundred ) times. Enjoy! My first reaction was "if you have to ask parts are required, you need to pay someone to do it for you". I stand by this reaction. Emily Here's another writeup: There are two ways to set the valve lash, one of which takes 2 hours andthe other takes about 3 hours. When I first did my cams, I figured thatyou had to have the timing belt cover off in order to see everything going on with the timing belt (read: timing marks). It helps, but its not necessary. To get the timing belt cover off, you have to remove both radiatorfans (two screws at the top and one fan plug on the bottom of each).With those out, you can remove the crank pully by removing the accessorybelts, putting your car in 5th gear, standing on the brakes, and havingsomebody run a long breaker bar. Once the pully is out, you can proceed to remove the 10-15 screws holding the timing belt covers on. From here you can remove your spark plugs and then rotate your motor clockwise with the crankshaft pully bolt. You need line up all the lines on the timing belt gears/pullies to the 12 o'clock position. There should be a timing mark on the gear in the middle and one on each camshaft pully. Now you can remove your valve covers(5 bolts). If the motor has been sitting for a little while, there won'tbe much oil coming out. With all the lines in 12 o'clock position, yourmotor should be in top dead center (TDC). This is where all of yourcylinders are at rest, but most importantly, cylinder 1 (front passengerside I think, though it says on your coil pack on the intake manifold)is at the top of the compression stroke. This is where you need eachcylinder to be when you set the valve lash.You will need a feeler gauge with .007" and .009". If you don't haveone, you can easily pick one up at any autoparts store for a couplebucks. You need to set the valve lash to .007" on the intake side and to.009" on the exhaust side. To do this, you push the feeler gauge in between the valve tappet and the top of the valve. If it is too loose, then you loosen up the 10mm nuton the end of your rocker arm, and with the use of a screwdriver, youcan screw the valve tappet down until it is pushing on the feeler gauge.Make sure you still has enough room to move the gauge back and forth,but tight enough that there is not slop if you wiggle the rocker up anddown. Now while holding the screwdriver in the slot on the valve tappet(to hold the tappet in place), keeping the feeler gauge under the valve tappet stil, you then screw the 10mm nut back down, securing the valve tappet in place. Recheck the lash with your feeler gauge.If it is still tight, but moderately movable, then you can move on tothe next valve; if not, try again. The intake side will be done from thetop of the car, and the exhaust side was done with one person below andone person above the car.Once you have done both the intake and the exhaust side of cylinder #1,you need to rotate the motor slowly clockwise until cylinder #2 (frontdrivers side) is at the top of the compression stroke. To check this,you just put your hand over the spark plug tube and as the cylinder iscoming up, you will feel air pushing on your hand; it will also begiving a hissing sound as air is being pushed around. If you take aflashlight and a mirror and use those to look down into the sparkplug hole, you should be able to see the piston. Once it has stopped moving (top) then you are there. If you wiggle the crankshaftbolt back and forth, you can see where the piston is sitting. Now yourepeat the vavle lash procedure for both intake and exhaust side forcylinder #2. Then you cycle the motor over to cyclinder #3 (backpassenger side), set the lash, then cycle to cylinder #4 (back driversside), and set lash.You are now done with setting the valve lash and you can begin reassembly of the car by putting the valve covers back on, the timing belt cover, the crankshaft pully (torqued back down to 130ft/lbs if its the stock pully), radiator fans, and plugs and wires. Reset your ECU.The shorter procedure simply bypasses the removal of the timing belt cover. You still have to remove plugs, valve covers, and radiator fans however. Since the crankshaft pully is keyed, it will only go on one way. While rotating the motor around with the spark plugs removed, you should be able to see a little knick or line on the backside of the crankshaft pully. If you watch for the compression on cyl. #1 while rotating the knick up to the top, you should be able to find TDC with the timing belt coverstill installed. It should take 720 degrees to rotate the motor throughone entire revolution. Once TDC is found, you can follow the stepslisted above to set the valve lash then rotate to the next cylinder andrepeat. Quote Link to comment Share on other sites More sharing options...
nelstomlinson Posted April 11, 2023 Share Posted April 11, 2023 @ccrinc, thanks, I roughly followed your instructions, and took care of a ticking noise on the passenger side of the engine. The #3 intake vales were a little loose, and the exhaust valves were probably double the lash they should have had. I must have messed up setting them when it was on the stand, but it's not too hard to do in the car. Anyway, it's running great now, no ticking, and the CEL hasn't come on again. 1 Quote Link to comment Share on other sites More sharing options...
