removing cv off tranny stub
Circlip inside holds it. Just like the axles on every other car on the road. No more special Subaru where you can change the axles without dumping fluid everywhere.
Pry-bar between the axle cup and the trans. Use the bolt that holds the bearing retainer ring as a fulcrum. A quick pop should get it out. If not, apply pressure and give the prybar a good smack with a hammer.
