LucasP Posted September 23, 2015 Share Posted September 23, 2015 So I noticed today that the car... 87 gl sedan with a weber... is leaking coolant from right where my intake bolts to the head on my driver side. Idk why it would be leaking there, is there a coolant line there? I know there is the actual coolant line running by the intake there but it is clearly leaking from the gasket between the head and intake. Can anybody shed some light on why it would be leaking there? Link to comment Share on other sites More sharing options...
ford'ssubaru's Posted September 23, 2015 Share Posted September 23, 2015 Coolant goes through the intake.... Replace with OEM Subaru gaskets and it will be fine. Link to comment Share on other sites More sharing options...
LucasP Posted September 23, 2015 Author Share Posted September 23, 2015 On 9/23/2015 at 3:21 AM, ford'ssubaru's said: Coolant goes through the intake.... Replace with OEM Subaru gaskets and it will be fine. Thanks. I figured it was just a gasket replacement. Link to comment Share on other sites More sharing options...
ihscout54 Posted September 23, 2015 Share Posted September 23, 2015 On 9/23/2015 at 3:21 AM, ford'ssubaru's said: Coolant goes through the intake.... Replace with OEM Subaru gaskets and it will be fine. This is definitely one of those parts that you buy OEM. There are brands that resell old Subaru inventory or make the gaskets to OEM specs, so you dont have to go to the dealer. I guess the point Im trying to make is; do not use the thick paper ones (Felpro). Unless you plan to do the gaskets again in 8 months. 1 Link to comment Share on other sites More sharing options...
DaveT Posted September 23, 2015 Share Posted September 23, 2015 Often the 6 bolts that hold the manifold to the head are difficult to remove. I have found the best way to remove them is to run the car until it is at normal operating temperature. Then gently work them out, while it is still hot. 1 Link to comment Share on other sites More sharing options...
ford'ssubaru's Posted September 23, 2015 Share Posted September 23, 2015 Absolutely right. Turn a little back tighten. Turn a little tighten. Reinstall with Copper coat or Never Seize.^^^^^^^ Link to comment Share on other sites More sharing options...
ihscout54 Posted September 23, 2015 Share Posted September 23, 2015 And if its bad enough to leak, be gentle during removal youll probably snap one or two. Link to comment Share on other sites More sharing options...
DaveT Posted September 23, 2015 Share Posted September 23, 2015 I have not snapped a bolt since discovering the patiently work them out while hot trick. Some were very stuck. Link to comment Share on other sites More sharing options...
LucasP Posted September 24, 2015 Author Share Posted September 24, 2015 Thanks everybody. I stopped by the dealer today and picked them up. Didn't have any issues with the bolts. I don't have it apart yet I just pulled the bolts out and cleaned them up. I'll get back to it on Saturday Link to comment Share on other sites More sharing options...
LucasP Posted September 24, 2015 Author Share Posted September 24, 2015 Anybody know off hand what the torque is on the 6 bolts? Link to comment Share on other sites More sharing options...
coxy Posted September 24, 2015 Share Posted September 24, 2015 Thirteen to sixteen foot pounds Link to comment Share on other sites More sharing options...
