Leaking coolant from intake gasket?
LucasP
So I noticed today that the car... 87 gl sedan with a weber... is leaking coolant from right where my intake bolts to the head on my driver side.  Idk why it would be leaking there, is there a coolant line there?  I know there is the actual coolant line running by the intake there but it is clearly leaking from the gasket between the head and intake.  Can anybody shed some light on why it would be leaking there?
Coolant goes through the intake....  Replace with OEM Subaru gaskets and it will be fine.
This is definitely one of those parts that you buy OEM. There are brands that resell old Subaru inventory or make the gaskets to OEM specs, so you dont have to go to the dealer. I guess the point Im trying to make is; do not use the thick paper ones (Felpro). Unless you plan to do the gaskets again in 8 months.
  • Like 1
Often the 6 bolts that hold the manifold to the head are difficult to remove. I have found the best way to remove them is to run the car until it is at normal operating temperature. Then gently work them out, while it is still hot.
  • Like 1
