sirtokesalot Posted September 24, 2015 Share Posted September 24, 2015 well the trans cooler lines rusted throgh on my 95 legacy im currently trying to sorce a new set somewhere but i have a question about them. what is involved in replacing them? it looks like i might gave to remove the rear cross member and lower the rear of the trans to get to the bolt for the line . can it be done without lowering the trans? does anyone have any good tricks for this job? Link to comment Share on other sites More sharing options...
sirtokesalot Posted September 24, 2015 Author Share Posted September 24, 2015 well so far i weaseled the bad line out of there not quite sure yet how im going to get it back in. Link to comment Share on other sites More sharing options...
sirtokesalot Posted September 24, 2015 Author Share Posted September 24, 2015 ok no part store can find a cooler line for the car. does the line need to be a banjo fitting? could i just go buy a 90 screw in fitting with a hose barb on one end and just run rubber line from the trans to the cooler up front? Link to comment Share on other sites More sharing options...
sirtokesalot Posted September 24, 2015 Author Share Posted September 24, 2015 at this point im about to just coat the line in p.o.r. 15 and let it dry and trogh it back on because i cannot find a replacement line anywhere. Link to comment Share on other sites More sharing options...
sirtokesalot Posted September 24, 2015 Author Share Posted September 24, 2015 fixed. i cut the end off the metal line shoved a rubber hose onto it all the way up to the bajo fitting and hose clamped it to the line then attached the other end up front. Link to comment Share on other sites More sharing options...
porcupine73 Posted September 26, 2015 Share Posted September 26, 2015 (edited) I just had that issue on my '96 Legacy. I do not think there is an aftermarket offering for those lines. I got mine from subarupartsforyou. The only tool I had that would get at the banjo fitting was a 19mm flex head gearwrench I happened to have. That worked pretty well. Plus there is a slight bit of give on the trans so you can jam a piece of wood or something between the trans case and body to get a little extra wiggle room. Have your trans cooler hard lines under the battery rusted out yet? If not I'd look at them since if your hard lines on the trans rusted out the ones under the battery are probably close too. And rear brake lines if those haven't rusted through yet and started leaking fluid somewhere above the fuel tank. Edited September 26, 2015 by porcupine73 Link to comment Share on other sites More sharing options...
Fairtax4me Posted September 26, 2015 Share Posted September 26, 2015 If it just rusted out along the frame just replace that frame section with rubber ATF cooler hose. I've never had to replace the ones that actually attach to the trans, but I know you won't find them aftermarket. If the banjo fitting is OK, but the line is rusted out, cut the bad section off, flare the end and run 3/8" rubber ATF cooler hose from there to the radiator. I get it at Napa for about $3 a foot. Link to comment Share on other sites More sharing options...
